Activity › Forums › Adobe After Effects › Smooth shakes
Smooth shakes
Posted by Clause Darius on August 20, 2019 at 2:23 pmI was wondering if anyone here knows how to do these smooth quick shakes, that mostly Instagram editors use.
Clause Darius replied 7 years, 1 month ago 2 Members · 8 Replies -
Richard Garabedain
August 20, 2019 at 3:12 pmits just a regular wiggle…probably attached to slider controls to make it easier to animate
Clause Darius
August 20, 2019 at 5:53 pmnot to be rude or anything, but I asked HOW to do it, not WHAT it is, ik what it is, im not that dumb, it’s an s shake/ s dissolveshake combined with brightness
Richard Garabedain
August 20, 2019 at 6:25 pmI did tell you how…But I did not realize how much of a beginner you were.. You create a null or a solid and add two slider effects to it. then you create your wiggle(1,2) and you highlight 1 and pick whip to slider 1 and then for 2 on slider 2. slider 1 is how many times per second and slider 2 is pixel distance
Clause Darius
August 21, 2019 at 6:55 amI don’t think we’re talking about the same thing… I’m asking about how to do the quick shake and brightness. Not the wiggle effect, I already know how to do the wiggle effect…
Richard Garabedain
August 21, 2019 at 3:23 pmwhat is the difference between a shake and a wiggle? YOu just make the wiggle last half a second and its a shake. ..but add a fast blur and a exposure or a glow and that should replicate the effect exactly….on the steven universe video
Clause Darius
August 21, 2019 at 4:46 pmuhh, I guess, but how do I do the wiggle? Just the usual way, with an S shake, or wiggle -rotation and wiggle -position?
Richard Garabedain
August 21, 2019 at 7:36 pmjust do the position…i have found that once you start shaking in 3d space, it just looks wrong. keep it 2d just wiggle the comp at the end with sliders
Clause Darius
August 22, 2019 at 3:25 pmThanks for the help, it actually helped, ty.
(end of thread)
