Activity Forums Adobe After Effects smooth painting
  • smooth painting
    Posted by Luis Ozonas on August 22, 2010 at 8:41 pm
    A classical problem with pen and mouse painting in several apps. When you paint with any brush, I get a disappointing angled stroke, and the faster goes the pencil, the worst. I wonder if this is a parameter issue, or maybe a processor, software problem?
    thanks
    Luis Ozonas replied 16 years ago 2 Members · 2 Replies
  • Haik Katsikian
    August 28, 2010 at 6:42 pm
    Hi Luis,
    Are you using the paint command? If your shapes are simple like that It might also be worth it for you create the shapes in Illustrator as vector files and then bring them into AE…
  • Luis Ozonas
    August 29, 2010 at 7:48 am
    Thanks Haik, but the idea is to take advantage of the paint tool options, in this case applying a write-on effect. That’s why I need a smooth and perfect curves, no matter the fast I draw.
    thanks
    Luis
