Activity Forums Zaxwerks Smooth out image
  • Smooth out image
    Posted by Stephen Smith on January 28, 2011 at 5:38 pm
    I purchased a 3D model of a car. It went into Zaxwerks Pro Animator GREAT. Everything is awesome. When I export it out of Motion set to Export Rendering = Software I get a hood that looks not smooth. Any way to smooth it out?
    I exported all three render setting with no luck, set to best as well and makes no difference.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
    Stephen Smith replied 15 years, 6 months ago 2 Members · 5 Replies
  • Stephen Smith
    January 28, 2011 at 9:15 pm
    One other thing. When I first bring it into Zaxwerks it looks great. If I save the project and re-open it then I get the non-smooth surface.
    Stephen Smith
  • Edward Wu
    February 4, 2011 at 7:02 pm
    Hi Stephen,
    Try going into the “Object” tab and going into the Info section, and change the “Hard Shading Angle” to “40”. If that value does not work well for you, you can try changing it to different values and seeing if it works better for you.
    Best,
    Edward
  • Stephen Smith
    February 4, 2011 at 8:08 pm
    Object tab? I’m not sure I understand. The Object button only has options to import illustrator elements, create text, etc, etc. Not sure if I’m looking in the right place.
    If I create the element and never close it out and re-open it…it maintains its smooth surface. It only goes crappy once I save, close out Motion and then re-open it. So I’ve written down all of the nurmeric values for the animation so I can always create it from scratch every time the client makes a change. Ouch.
    Stephen Smith
  • Edward Wu
    February 4, 2011 at 8:19 pm
    Hi Stephen,
    I am referring to the “Objects” panel, where you can adjust the Depth, SpikeBuster, etc. Expand the controls for “Info”, and change the Hard Shading Angle.
    Best,
    Edward
  • Stephen Smith
    February 4, 2011 at 8:57 pm
    I tried it twice and it keeps crashing Motion. I’ll try again next week after the computer can sit unplugged for the weekend. The spot is due in an hour and the solution I wrote about in my last post has been getting me by.
    Stephen Smith
