Activity › Forums › Adobe After Effects Expressions › smooth oscillation between keyframes?
  • smooth oscillation between keyframes?
    Posted by Nate Biehl on January 17, 2024 at 10:22 pm
    Hello!
    I have this expression to smoothly oscillate a shape layer between two points:
    y=value[1];
    a=20;
    p=effect("X Position Offset")("Slider")*10;
    f=effect("Frequency Slider")("Slider")/5;
    x=[Math.cos(time*Math.PI*f)*a]+p;
    [x,y]
    I would like to keyframe the frequency slider to smoothly transition from one frequency to a higher frequency, but when I add keyframes to the slider the frequency goes berzerk between the keyframes. Is there a way to make the transition smooth?
    Thank you!
    Brie Clayton replied 2 years, 8 months ago 3 Members · 3 Replies
