Activity Forums Apple Final Cut Pro Legacy Smooth my pan shot
  • Smooth my pan shot
    Posted by Tobias Schrenk on September 1, 2010 at 11:17 am
    Hey,
    I have a problem with a pan shot. Inside of Final Cut the pan looks quit okay but when I am exporting it it´s not really smooth. It stucks here and there. Is there a Final Cut plugin to smooth the movement of the pan? Or any other way ?
    I would be very thankful for any help.
    Best
    Tobias
    John Fishback
    replied 16 years ago
    3 Members · 2 Replies
  • Jerry Hofmann
    September 1, 2010 at 12:45 pm
    Which export command are you using and what are the settings you’re using? Also post the format of the source files and sequence settings.
    If you are playing the export from your startup disk, this could be the reason it’s not smooth, because you’re dropping frames. Be sure to test it on your scratch disk, and not your startup disk.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • John Fishback
    September 1, 2010 at 7:14 pm
    Sometimes the frame rate of your video can beat with the frame rate of your computer display to produce less than desirable results. It can look great on a broadcast monitor, but funky in places when playing back on the computer.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
