Activity Forums Adobe After Effects Smooth minimalistic animation
  • Smooth minimalistic animation
    Posted by Noname Noname on November 26, 2012 at 11:37 pm
    Hello,
    I’ve been working with AE a lot over the last couple of months and I can’t find any tutorials on achieving this type of animation https://vimeo.com/46316398. I tried experimenting for a bit by trying to mimic the background color transitions, but it just doesn’t seem fluid and smooth like in the video(even with easing on my keyframes). I tried motion blur as well, but since the animation is so fast they look like gradients, taking away from the very flat minimalistic look. If anyone could guide me in the right direction that would be greatly appreciated.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Hannes Paulsson replied 13 years, 9 months ago 3 Members · 2 Replies
  • David Chappell
    November 27, 2012 at 4:52 pm
    To stop your motion blur looking like a gradient you simply need to increase the quality.
    Composition Settings > Advanced > Samples per Frame (default I think is 16)
    For very fast animation with solid colours you may need to increase quite drastically – try 64 or even higher.
    Higher samples number = better quality motion blur = longer render times!
    With reference to the fluidity I think that it is just more practice & experiementing with keyframing… the example you posted was obviously produced by a highly skilled motion graphics animater.
    David Chappell
    Freelance Motion Graphics / 3D
    http://www.IncidentalTrees.co.uk
  • Hannes Paulsson
    November 27, 2012 at 10:18 pm
    And to add to that;
    to get better control over your keyframes, use the graph view and play around in there. You can adjust how smooth the keyframes act, and get a very precise control over the speed. Make sure to learn the difference between the value-graph and the speed-graph.
