Activity Forums Adobe After Effects Smooth Flickering
  • Smooth Flickering
    Posted by Allen Joaquin on June 27, 2012 at 9:29 am
    Hi, in a Project i’ve wanted to create a sort of flicker using gaussian blur and Brigtness and contrast, I’ve thought about using The loopout script. “loopOut(type = “pingpong”, numKeyframes = 0)” with some keyframes but i was wondering if there is any way i could make it go faster then the actual speed it has.
    Because the flickering it’s not as fast as i’d want it.! How could i fix this? Or is there any way appart from dong keyframe by keyframe? because it’s a huge comp.
    Thank you,
    Allen Joaquin replied 14 years, 2 months ago 2 Members · 2 Replies
  • Walter Soyka
    June 27, 2012 at 1:23 pm
    You could keep the loopOut expression and adjust the keyframes (select all keyframes, then Alt-drag the last keyframe towards the first to move all keyframes proportionately).
    You may also be able to precomp your flickering and use time-remapping, depending on how your project is built.
    Walter Soyka
  • Allen Joaquin
    June 28, 2012 at 12:09 am
    They keyframes dosen’t really matter i belive cause i got them exactly 1 frame from each other and it dosen’t goes as fast as it should. yeah i thought about time remapping too. but i was wondering if there was another way..
