Activity › Forums › Apple Final Cut Pro Legacy › Smooth Final Cut Pro scrolling credits
  • David Smith
    April 15, 2007 at 4:49 pm
    Sure!
    Search the final cut pro forum with keywords “scrolling text”. I got 88 hits from that search and I know there have been many posts with suggestions for this.
    Hit the Search button above. Set the search parameter for All Active Posts and make sure you choose only the Apple Final Cut Pro forum.
    Regards,
    David
  • Boyd Mccollum
    April 15, 2007 at 7:06 pm
    Check out Boris Crawl found in the Boris submenu of the video generators in FCP 5. The plugins are part of Boris Calligraphy. The PDF manual is located in the FCP application bundle, or can be downloaded from Apple:
    <https://manuals.info.apple.com/en/Boris_Calligraphy_2_User_Guide.pdf>
