Activity Forums Apple Final Cut Pro Legacy Smooth Cam Point of Interest
  • Smooth Cam Point of Interest
    Posted by Andy Lancaster on January 7, 2008 at 1:56 am
    Is there a way to tell Smooth Cam what the point of interest is on the shot? I am smoothing some aerial shots of a city and the sky scrapers’ tops are being chopped off. I need there to be less ground and more sky when it is scaled up.
    Mark Maness replied 18 years, 7 months ago 2 Members · 1 Reply
  • Mark Maness
    January 7, 2008 at 3:10 pm
    You can adjust for this, to a point. But what will usually happen is that you will start to see edges of your video.
    The reason why your buildings are being cut off is due to the fact that SmoothCam has figured the best smooth motion which means blowing up the image enough to keep from seeing the edges of your video frame. It takes into account of edges showing and blows up the image to crop these out.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
