Activity Forums Apple Final Cut Pro Legacy Smooth cam not so smooth after export
  • Smooth cam not so smooth after export
    Posted by Jordan Wilson on October 11, 2011 at 6:35 pm
    Here’s a new one.
    When I’m inside FCP7, smooth cam is working great. After rendering, the shots are super smooth and exactly how I want them.
    After exporting, though, they come out all jittery and whatnot. Not sure why this is happening.
    Footage is 1080 ProRes.
    Erick Benzi replied 14 years, 10 months ago 2 Members · 2 Replies
  • Jordan Wilson
    October 11, 2011 at 7:06 pm
    Found an old archived thread on this. Trying a couple different routes I found on there.
    If anyone else has been through this and knows the answer, please chime in.
    Right now I’m trying to use the “share” function instead of exporting. We’ll see how it goes…
  • Erick Benzi
    November 6, 2011 at 11:46 pm
    Hi, have you tried to set the field dominance to “none” in the setup of the timeline ? ( instead of odd or even)
    it worked just fine for me.
    same problem using Magic bullet “looks” plug-in.
    you can switch back if necessary after export
