Activity › Forums › Apple Final Cut Pro Legacy › smooth cam filter going haywire after export
  • smooth cam filter going haywire after export
    Posted by Tyler Hill on June 30, 2011 at 5:04 pm
    Hey guys, new to the forum and looking for some help. I produce a hunting tv show and my first episode aired last night. I was horrified to see that almost all of the clips i used the smooth cam filter on where out of control glitchy. This is the first time I have ever ran into this problem, everything looked great when it was rendered but for some reason the exporting process made it go nuts. I shot with a PMW-EX1R, and the TV station exports at Apple ProRes 422(HQ)1920×1080 60i 48kHz. I am a self taught editor (which translates to knowing jack about the technical side) so any help would be greatly appreciated. Also if anyone knows of a good steady cam filter that would be great. Tripods and steady cams are pretty much out of the question for were we film.
    Rob Grauert replied 15 years, 2 months ago 2 Members · 1 Reply
  • Rob Grauert
    June 30, 2011 at 6:17 pm
    When using smooth cam, don’t just throw it on the clip in your timeline all willy-nilly. For the best results…usually…export that portion of the clip you are using in your timeline as it’s own self-contained quicktime (with one or two second handles). Then bring THAT back into FCP and apply the smooth cam filter.
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
