Activity Forums Apple Final Cut Pro Legacy smooth cam – fcp 7 ugrade issue?
  • smooth cam – fcp 7 ugrade issue?
    Posted by J clive Jordan on September 17, 2009 at 4:04 pm
    Hello, any suggested are appreciated:
    I have lots of experience with ‘smooth cam’ and have used it very successfully over the years, but I just upgraded to FCP 7 and the output looks terrible – extremely shakey video that looked fine in fcp 6. It looks like it has field order issues.
    I tried re-rendering the mtdf file – that didn’t work
    I tried changing field order – that didn’t work
    I tried de-interlace – that didn’t work.
    any suggestions?
    j clive jordan
    http://www.kitesites.com
    check out the latest episode!
    Wolfgang Medicus replied 16 years, 11 months ago 4 Members · 5 Replies
  • Kevin Hamm
    September 17, 2009 at 7:23 pm
    Do you have any speed changes on the clips? We had this problem with a clip and we just removed the speed changes, re-rendered and it was fine, then added the speed changes back and it worked fine.
    The other option is to delete the analysis file and let it re-analyze the clip, but that would be a nightmare.
    Kevin Hamm
    Video, Web, Print and coloring books.
  • J clive Jordan
    September 17, 2009 at 11:21 pm
    no speed changes,, I guess I’m the only one with this problem. I also re-analyzed the clip – didn’t work..
    j clive jordan
  • Andres Garcia
    September 23, 2009 at 3:40 pm
    Hi I am having the same problem…somone there… that could help us?
    Andres
    Andres Garcia
    http://www.covisual.com
  • Wolfgang Medicus
    October 1, 2009 at 10:42 am
    I’m also having this problem. Cutting ProRes 4:2:2 HQ Progressiv Material. I tried several export codecs… but hopeless.
    Maybe a problem with Quicktime ?
    I have Player 10.0 installed.
    Someone any idea ?
  • Wolfgang Medicus
    October 5, 2009 at 8:14 am
    Hello again,
    here is a workflow to fix the problem:
    – Export the Clips (before smooth cam)
    – Reimport it in the timeline
    – Smooth Cam
    I used MPEG Streamclip to get the ProRes Files from a JVC Everio Camera (TOD-Files). It seams that Final Cut isn’t 100% compatibel with this.
