Activity Forums VEGAS Pro smooth arc
  • Theo Van laar
    August 25, 2009 at 10:26 pm
    Mark,
    Are you still in the need of a U-shaped path. I made another example. If that is what you are looking for, I might be able to help you.
    Check here:
    228_arcmovement.wmv.zip
    Theo
  • Mark Altland
    September 2, 2009 at 12:44 am
    Thanks for your help. I thought that was going to be the the answer, but it was worth trying.
  • Mark Altland
    September 2, 2009 at 12:47 am
    That is what I was eluding to. Since the post was started I thought of new ideas of what I am trying to do and the only result is more & more keyframes, which is what I was trying to avoid.
    How many keyframes were in your example?
    Mark
  • Theo Van laar
    October 5, 2009 at 3:25 pm
    Marc,
    I didn’t realize that you had replied again to this topic.
    I used only three keyframes in this example. But like I said, with a little bit of help from outside Vegas.
    If you still need this, you can send me the picture and I will animate it for you.
    Theo
  • Mark Altland
    October 5, 2009 at 3:40 pm
    That’s okay, but I appreciate your help.
    Mark
Page 2 of 2
