Activity Forums Adobe After Effects Smooth animation of text font
  • Smooth animation of text font
    Posted by Maxim Tincu on April 26, 2016 at 7:26 am
    I want to make this style of font animation – https://vimeo.com/50080784 at 39 sec. I don’t get it how he could achieve such smooth animation from one font to other.
    Thank you
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Maxim Tincu replied 10 years, 4 months ago 3 Members · 4 Replies
  • John Cuevas
    April 26, 2016 at 1:20 pm
    It’s a technique where you change the text into shape layers, try and match up vertexes and then animate between the two. Check out this tutorial.
    https://www.youtube.com/watch?v=oOZY7Yks6hI
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Richard Herd
    April 26, 2016 at 3:36 pm
    Regarding the typography:
    For me, this type of treatment takes quite a bit of time. I like to build each title card first in Illustrator, and then outline the text and copy-paste the paths into a solid layer. One bit that is a giant pita is to set the “correct” mask points to the first vertex: right click a point on the mask > Mask and path shape > Set First Vertex.
    Then set a key frame for that mask path, and copy/paste to a new location to set a keyframe. Then copy a new mask onto that keyframe. Suppose you want to turn an “F” into a “Z.” You’d copy the mask.
    Remember also that AE’s render order is SMET (Source, mask, effects, transform), so scaling a layer will “ruin” the mask.
    I’m all ears if someone has a better way.
  • John Cuevas
    April 26, 2016 at 3:46 pm
    Sorry, posted the wrong link…
    https://www.youtube.com/watch?v=rtKbMZqnYFE
    ThinkCK
  • Maxim Tincu
    April 26, 2016 at 3:54 pm
    Thank you very much John. This is what I was looking for. I have used paths, but the final result was horrible. I didn’t know about “Set First Vertex” option. Thank you very much
