Activity Forums Adobe After Effects Smooth 3d curves
  • Smooth 3d curves
    Posted by Ari Grunzeweig on February 4, 2010 at 8:02 pm
    I’m working on an animation where a molecule is moving in a 3d figure-8 motion around a larger molecule. I’ve keyframed it all in 3d using bezier curves. Here is my problem. When I perfect one dimension, for example, the front view, it looks great. Then once I perfect the next dimension, the top view, it messes up the front view. and so on and so on in a vicious circle. Any ideas on how to have all dimensions smooth at the same time?
    Bill Kelly replied 16 years, 7 months ago 4 Members · 4 Replies
  • Michael Szalapski
    February 4, 2010 at 10:22 pm
    I’m sure others will chip in, but here’s one way: just do your figure 8 in 2d, then switch the layer to 3d, create a 3d null, parent the layer to the null, then rotate the null.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Andy Blondin
    February 5, 2010 at 12:46 am
    You may what to create a path in illustrator or PS than copy and past it in as a motion path. That will get you the shape that you want and the speed should be consistent.
  • Ari Grunzeweig
    February 5, 2010 at 3:09 am
    Thank you for the tips.
  • Bill Kelly
    February 5, 2010 at 7:58 am
    I think this tutorial by maltannon is exactly what you want.
    https://maltaannon.com/articles/after-effects/simple-camera-rig/
