Activity Forums Adobe After Effects Smooooothing Animation
  • Smooooothing Animation
    Posted by Cutter Johnston on July 15, 2008 at 1:23 pm
    “How do I” really smooth out an animated figure in motion? Played with the curves in the graph editor, adjusted keyframes in the timeline, adjusted the motion paths and still there are spots that need smoothing. Using kinematics (parenting), effector layers and expressions to control the figure. It seems like I am either hypercritical or missing an industry secret.
    Cutter Johnston replied 18 years, 2 months ago 4 Members · 5 Replies
  • Chris Wright
    July 15, 2008 at 9:59 pm
    highlist the first and last frames of a single move to smooth, then hit easy ease or F9.
  • David Rickles
    July 18, 2008 at 8:07 am
    Can you post a clip?
    David Rickles
    Motion Designer | Editor
    David.Rickles@gmail.com
    http://www.davidrickles.com
  • Darren Gardner
    July 23, 2008 at 9:03 pm
    Try this expression:
    smooth(width=.5, samples=25, t=time)
    apply it to your position property or to whatever property you’re using to animate by keyframing.
    If the motion’s still not quite right, try raising or lowering the width parameter. Something like .75 or .25.
    I found this solution on the COW some time ago and its worked great!
    Darren
  • Cutter Johnston
    July 24, 2008 at 6:20 pm
    thank you Darren. I will give it a try
  • Cutter Johnston
    July 24, 2008 at 6:22 pm
    David, thank you. I am back at it now. I will figure out how to post a clip. It may be on my site and I will forward the URL.
