Activity Forums Adobe After Effects smoky words
  • smoky words
    Posted by Stephman74 on June 6, 2006 at 2:03 pm
    I have a brief where the client wants a number of key words to resembnle smoke that become filtered through their air purifier. I have looked at the smoke tutorial in the tuts section however where the tutorial has a basic mask to be used as a wall when I bring in a mask from illustrator that is a key word, the smoke fails to follow the wall. Any ideas please.
    to solve problems of today we must focus on tomorrow
    Stephman74 replied 20 years, 3 months ago 3 Members · 3 Replies
  • Mark
    June 6, 2006 at 2:08 pm
    Create the letters using the text tool
    Next, create a new comp and create the smoke using fractal noise
    Now use that new comp as a displacement map and a luma matte for the text. Play around with transparency and very eased position keyframes.
    You should be able to get something really smoky with this.
    You can also dupe the text and offset the second layer by using blur and different displace amounts.
    Regards
    Mark
  • Justin Productions
    June 6, 2006 at 2:45 pm
    If you have Trapcode Particular, they have good presets on trapcode-people dot net . You could send me your footage at my adress with a short description on how you want the text, and what is the word you want to “smokey”.
    Good luck!
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
  • Stephman74
    June 6, 2006 at 3:42 pm
    cheers guys for the response. FAO of Justin I have mailed you the ae file as requested, Cheers for this, very much appreciated.
