Activity Forums Maxon Cinema 4D Smoke trail renders only as puffs
  • Smoke trail renders only as puffs
    Posted by Steve Barnier on February 12, 2014 at 5:43 pm
    I’m trying to make a smoke trail coming out from a jet flying overhead. When I render the current frame with Render to Picture Viewer the smoke trail looks correct. But when I render as a full animation all I get is a trail of individual puffs. Is there a setting I should be aware of?
    Steve Barnier replied 12 years, 6 months ago 2 Members · 5 Replies
  • Brian Jones
    February 12, 2014 at 6:02 pm
    Standard particles?
  • Steve Barnier
    February 12, 2014 at 6:19 pm
    Yes (not using Thinking particles). I’m using the pyrocluster shaders for the emitter and the Environment.
  • Brian Jones
    February 12, 2014 at 6:31 pm
    there are separate settings for editor and render particle counts, is the render count the same as the editor count? (Birthrate Editor/Birthrate Renderer)
  • Steve Barnier
    February 12, 2014 at 6:36 pm
    I’ve had them both set to 1000. I even set the Render Count to 10,000. It didn’t make any difference.
  • Steve Barnier
    February 12, 2014 at 8:09 pm
    Well, I just discovered, and then read, that pyrocluster doesn’t work with the physical Renderer (which is what I was using). I hope they fix that soon.
