Activity Forums Maxon Cinema 4D Smoke on the water
  • Smoke on the water
    Posted by Sam Vargas on January 23, 2007 at 10:36 pm
    Hi again, I’d like to create smoke like cigarette’s, emitting from a specific object’s surface. I think it’s the same when steam comes from the lake’s surface. But I cannot make smoke with the pyrocluster, which is similar to cigarettes, long with turbulance. And I cannot make particles emitting from a surface. Is it possible to make ?
    Sam Vargas replied 19 years, 8 months ago 4 Members · 6 Replies
  • Adam Trachtenberg
    January 23, 2007 at 11:02 pm
    I believe Cinema comes with a TP preset for emitting particles from a surface.
    Regarding that kind of smoke, it’s actually a very had thing to achieve convincingly in 3D. Ultimately it requires fluid simulation, which isn’t available in Cinema and, in any case, is very cpu intensive.
    The best results I’ve seen used animated geometry with fresnel in the transparency channel.
  • Sam Vargas
    January 24, 2007 at 11:15 am
    Thank you, anyway, I try to achieve at least something similar to things I have in my mind.
    If there’s a way to export/import the whole scene to max/maya and if those have the capabilities for this type of animation, would it be a solution ? I mean, is this possible ? This should be just a few (around 10) second long piece of the whole animation. (sorry, if i express myself in a complicated way)
  • Samir Kharchi
    January 24, 2007 at 11:33 am
    Hi Sam,
    fluid simulation of gases can be found very soon in DPIT Nature Spirit V4 for Cinema 4D.
    Find more information regarding this here:
    https://www.dpit2.de
  • Bounce
    January 25, 2007 at 1:44 am
    What about Realflow? They have a import/export plugin for C4d.
    https://www.nextlimit.com/realflow/features.htm
  • Bounce
    January 27, 2007 at 8:42 pm
    Ok, This worked for me with TP. You will need to adjust the light to get the look you are after.
    https://dougbassett.com/smokewater.png
  • Sam Vargas
    January 28, 2007 at 9:10 am
    Oh, that’s great. Thanks. I’m fine tune then.
