Activity Forums Maxon Cinema 4D Smoke, inside fog?
  • Smoke, inside fog?
    Posted by Tim Vining on May 16, 2018 at 4:53 pm
    Trying to show simple non-animating chimney smoke rising over a foggy city. It’s a wide shot, so I tried first a smoke image with an alpha on a plane, but the alpha shows as a dark translucent box, and from what I have read, this still seems to be a known problem for over a decade with alphas & fog. I know about using a giant visible light to simulate the fog instead, but wondered if anybody had any other suggestions?
    (For a bonus, can anybody explain why a visible light can play well with alphas, but fog can’t, when this has been a known issue for years?)
    Thanks–Tim
    Tim Vining replied 8 years, 4 months ago 2 Members · 4 Replies
  • Steve Bentley
    May 16, 2018 at 8:23 pm
    Have you tried putting your “alpha” for the smoke in the transparency channel of the texture? (usually you have to invert it though – white is “clear” in the trani channel.)
  • Tim Vining
    May 17, 2018 at 9:09 am
    Yes, thanks, I did try that and it looked the same. How apparent the alpha/trans looks seems to depend somewhat on what is behind it. The landscape above the wall is dark, so the alpha seems to be very dark.
  • Steve Bentley
    May 17, 2018 at 3:24 pm
    I had this problem a while ago and did solve it. I’ll try and dig up the file. But in the mean time, I remember fiddling with the matte object check box in the compositing tag or including a background plane that the camera couldn’t see (or both)
  • Tim Vining
    May 18, 2018 at 1:27 pm
    Okay, thanks! I looked into the compositing tag and didn’t find a solution, but I’ll take your suggesting to look into it some more. A solution for this would be great–I’m embarking on an animated fantasy project, and that means lots of fog, mist & smoke!
