Activity › Forums › Maxon Cinema 4D › smoke in a cube
smoke in a cube
Posted by Zach Gunter on June 9, 2008 at 6:07 pmI’m needing to make an ICE CUBE that has smoke contained in it…..HELP. how could this be accomplished.
Samir Kharchi replied 18 years, 2 months ago 4 Members · 8 Replies -
Adam Trachtenberg
June 10, 2008 at 3:28 amYou could use pyrocluster or you could map textures to planes inside the cube. You’d be better off with pyrocluster if it needs to be animated.
Zach Gunter
June 10, 2008 at 3:39 ameveryone talks about pyrocluster. I can’t find it in the program. where would i look for it. In the content browser is only gives me like 8 still pictures.
Randy Johnson
June 10, 2008 at 6:08 amIf you are going for a still image I suggest placing a bitmap on a plane inside the cube like Adam suggested.
You can make nice smoke with a light and noise too. There is a thread at c4d cafe that has a few example project files posted search Mograph Smoke.
Pyro cluster is found in the the materials manager. (default bottom of the screen)
materials: file: shader there you will find a volume tracer and pyrocluster… for pryro to show up you need to put the volume tracer on an enviroment object. Enviroments can be found in the lights drop down menu. Then place the pyrocluster on an emitter…play a few frames and render.Inside the pyrocluster material you can choose smoke, fire and a few others.
/randy
Samir Kharchi
June 10, 2008 at 7:37 amCheck out DPIT Nature Spirit (commercial). It�s the very best solution for realistic smoke animation. Inside a cube shape is the easiest thing it can do. Check out the plugin here: http://www.dpit2.de
For a still image you could use it of course too, but maybe an image map is faster and easier here.
Plugindevelopement and Graphic Visualization
Randy Johnson
July 15, 2008 at 7:46 pmI did not really think that smoke in a box could be the easyest thing any plug in could do until i got it.
Haha one botton…thats really cool./Randy
Samir Kharchi
July 16, 2008 at 9:42 am@randy: ;-D
@zach: just look at http://www.dpit2.de into the gallery or even better, simply download the trial version from the website and see for yourself. 🙂Plugindevelopement and Graphic Visualization
