Activity › Forums › Adobe Photoshop › Smoke Brushes
  • Smoke Brushes
    Posted by Steve White on February 16, 2013 at 8:42 am
    Hi all
    Just downloaded some free smoke brushes and can’t get them to work in cs6 im on a pc.They loadup ok but when i add one to a black background the brush is solid and has no transparency to it.Am i missing some settings?
    Thomas Alexander replied 13 years, 6 months ago 3 Members · 6 Replies
  • Jonathan Ziegler
    February 16, 2013 at 5:54 pm
    Can you give the link to where you got the free brushes? I’ll try them out and make sure the problem isn’t the brushes. 🙂
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
  • Steve White
    February 17, 2013 at 12:12 am
    Sure
    https://www.brusheezy.com/brushes/1830-real-smoke-photoshop-brushes
    But have tried a few and all react the same but have tried a brush that is not a. Smoke brush and everything works ok
    Many thanks. Steve……
  • Jonathan Ziegler
    February 17, 2013 at 4:28 pm
    Ok, so here’s what I did:
    Download and unzip the brushes.
    Launch Photoshop
    Create a new file (I used Photoshop Default) and click the brush tool.
    Go to the brushes palette, load your brush ABR file, select one of the brushes, and voila, it looks like it works.
    The problem is likely a setting on your end or a problem with the download. Try downloading again?
    Can you list the exact steps you took?
    Jonathan Ziegler
    520-360-8293
  • Steve White
    February 18, 2013 at 12:10 am
    Seem to have fixed things for now it’s only happening with new brushes I have downloaded.the fix is to not load the brushes but to replace them ie only load the brush I need not add to the brushes already in my pallet
    Bug?
    Thanks for your help Steve…….
  • Jonathan Ziegler
    February 18, 2013 at 5:41 pm
    Steve, that’s a little odd. What version are you using? I’m on CS3 on this machine (its the one I tested it on). I haven’t tested CS6 (it’s at the office), but I add brushes at least every month to some degree and I haven’t seen that. Maybe talk to Adobe?
    Jonathan Ziegler
    520-360-8293
  • Thomas Alexander
    February 26, 2013 at 10:49 am
    Make sure your plugins are loaded and have use a white background.
    Thomas Alexander | Independent Cinematographer
    Soulman Films | Nicosia Cyprus | +357-97697640
