Activity Forums Apple Final Cut Pro Legacy smeared frames in FCP
  • smeared frames in FCP
    Posted by Peter Dewit on November 10, 2006 at 3:47 pm
    I’ve noticed lately that sometimes FCP is vertically smearing video frames. I’ve double checked my tapes and the disgtortion is definately happening during capture. It seems to be random(if I recapture the frame is usually fine). I’m captureing via SDI on a Kona2 card from a J3 deck. The deck was recently serviced so I doubt thatis the issue. This has been happening onmultiple tapes. That leaves the Kona card or the computer as the cause.
    Any ideas?
    Ben Holmes replied 19 years, 10 months ago 3 Members · 2 Replies
  • Thaxter Clavemarlton
    November 10, 2006 at 3:53 pm
    “Field Order” issues?
  • Ben Holmes
    November 10, 2006 at 10:13 pm
    Smeared? Do you mean that some frames are incomplete, with the same line repeated all the way down from a certain point?
    If so, it’s an IO problem, and could be the card or the disk array – sorry not to be more specific, but you’ll need to try removing components and isolating the problem. Try using the card to capture DV of some flavour to a FW drive…
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live OB operations. FCP systems just used on Sky Sports coverage of the Ryder Cup – live from the K Club.
    “The Supercar Run” now available for international distribution from http://www.electricsky.com
