Activity Forums Avid Media Composer SM_DF_NDF_MISMATCH ERROR merge ALE with AMA clips
  • SM_DF_NDF_MISMATCH ERROR merge ALE with AMA clips
    Posted by Ben Mills on May 4, 2012 at 1:11 pm
    Hi there,
    I am having problems when merging an ALE with a bin of AMA clips.
    The ALE is all present and correct and will import into a bin with the “Maintain events as logged” setting checked.
    Unfortunately I cannot use the “Merge events with known master clips” option to merge the ALE with my AMA clips.
    I get the error “An error occurred on event #1 Exception: SM_DF_NDF_MISMATCH”
    I’ve tried modifying the AMA clips between NDF and DF but doesnt make a difference!
    Any ideas anyone?
    Many Thanks.
    Ben Mills replied 14 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
