Activity Forums Adobe After Effects Smash effect
  • Smash effect
    Posted by Mirek on October 31, 2005 at 7:05 pm
    I am looking for an effect to smash a sequence or picture into pieces like smashing a window.. Do I have to use particle systems to do that ?
    CHeers
    Andrei Firtich replied 20 years, 10 months ago 3 Members · 6 Replies
  • Steve Roberts
    October 31, 2005 at 7:09 pm
    Try effect>simulation>shatter.
    Steve
  • Mirek
    October 31, 2005 at 7:43 pm
    I find it quite hard to adjust so many parameters …I need just simple explosion to pieces falling on the ground.. Can you please just tell me on which parameters should I focus ?
  • Steve Roberts
    October 31, 2005 at 8:09 pm
    Basically, try reducing the force 1>strength, changing the shape>pattern to “glass” and increasing physics>gravity.
    If you want to know more, check out this Shatter tutorial by Ben Unguren on the COW.
    Steve
  • Mirek
    October 31, 2005 at 8:47 pm
    do i have to animate it somehow to see the result ? The effect in the tutorial is applied to text effect and I dont know for what reason but when I apply it to my video I do not achieve any result ..
    Thanx a lot for help so far..
  • Steve Roberts
    October 31, 2005 at 8:58 pm
    Nope, you don’t have to set keyframes — it’s self-animating. Just try applying it to your video layer, then do a RAM preview as it is. Next, change the settings as I described to make it more like what you want.
    Only go to the tutorial once you get the basic shattering happening.
    Steve
  • Andrei Firtich
    November 1, 2005 at 6:37 pm
    In the view parameter select Rendered, and you should see the results. The Default is wireframe+forces, thats why you can’t see anything.
