Activity › Forums › VEGAS Pro › Smart Rendering Frustration
  • Smart Rendering Frustration
    Posted by A.miller@yourmusicmuse.com Mueller on April 21, 2012 at 1:20 pm
    I have used a render preset that I made back in vegas 9. It is an mpeg2 render and I used to be able to render out my videos and then make minor changes/cuts with smart rendering. It was great.
    When I upgraded to vegas 10 I used the same preset but now it doesn’t let me smart render. I tried changing some settings but to no avail.
    Can you guys take a look at these screen caps and see if you notice anything that would prevent me smart rendering with this render preset?
    Here are the caps:
    https://imgur.com/a/yOkGs#0
    Lee
    Director Of Video Production (yes this is made up)
    https://www.yourmusicmuse.com
    Smart Render
  • John Rofrano
    April 21, 2012 at 7:08 pm
    Could you please attach the screen shots to your post here at the COW? The site you used says that it’s over capacity so we can’t see them.
    Here’s how:
    Press the Add Image button
    Then upload your image and cut & paste the link in your post.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • A.miller@yourmusicmuse.com Mueller
    April 22, 2012 at 2:05 am
    So I render with this one originally and then i pop the file back into vegas and match media settings so the project is exactly right.
    Then I make a cut or two and hit render using this exact same render profile.
    Lee
  • John Rofrano
    April 22, 2012 at 2:10 pm
    [Lee Mueller] “Can you guys take a look at these screen caps and see if you notice anything that would prevent me smart rendering with this render preset?”
    Here are the big differences I see:
    (1) On the Advanced Video tab, your DC coefficient is set to 11 bit and in my Vegas Pro 11.0 it only goes up to 10 bit and the default is 9 bit.
    (2) Your Sampling format is 4:2:2 and the default is 4:2:0 and it’s not editable. I have no idea how you changed that.
    I would just make a new custom template in Vegas Pro 10 and use that and see if it smart-renders. Understand that smart-render will only work if the source video matches the render format exactly.
    ~jr
    April 23, 2012 at 3:22 pm
    Ok thanks for looking into it John. I am rendering from the same preset so everything is the same and it worked before in vegas 9. I guess it is just a glitch in vegas…
    Will try what you said and post here if I have success.
    Lee
