Activity Forums Apple Final Cut Pro Smart backup of Library packages?
  • Smart backup of Library packages?
    Posted by James Culbertson on July 2, 2014 at 11:56 pm
    Is there an application that can smart backup a library package?
    I use ChronoSync for backup currently, but even if there is only a small change to the project portion of a library package, Chronosync wants to backup the whole library package again. Kind of a PITA when you have 100’s of Gigabytes or more in a library package.
    Robin S. kurz replied 12 years, 2 months ago 5 Members · 6 Replies
  • Dave Jenkins
    July 3, 2014 at 1:29 am
    Smart Sync (full version) will back up just what’s changed inside the package. I’ve e-mailed the developers with suggestions. Each time within a week they implemented my suggestions.
    It can be found on the App Store.
    Dajen Productions, Santa Barbara, CA
    Mac Pro 3.5MHz 6-Core Late 2013
    FCP X
  • Tim Jones
    July 3, 2014 at 3:45 am
    Of course, my favorite is BRU PE which will not only backup the bundles, but also track down any referenced files.
    You can create a Full job that contains your bundle libraries and then create an incremental definition that will only include the modified/added files.
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.productionbackup.com
    BRU … because it’s the RESTORE that matters!
  • Brett Sherman
    July 3, 2014 at 4:32 am
    Have you tried checking the “Dissect Packages” option in Chronosync?
  • James Culbertson
    July 3, 2014 at 5:14 am
    [Brett Sherman] “Have you tried checking the “Dissect Packages” option in Chronosync?”
    Ah, that sounds like a winner. I searched the documentation for packages but nothing turned up.
  • Robin S. kurz
    July 3, 2014 at 7:46 am
    Then there’s always the very pragmatically named Backups for Final Cut Pro: https://itunes.apple.com/app/backups-for-final-cut-pro/id586594646?mt=12
  • Robin S. kurz
    July 3, 2014 at 9:12 am
    But I personally simply use FCP’s own backup feature and have set it to back up to my Copy folder. https://copy.com?r=D4Fz3M
