Activity Forums Adobe After Effects SmallVille transition effect
  • SmallVille transition effect
    Posted by Manny Rellesiva on November 2, 2005 at 12:52 pm
    In the new season (5) of Smallville, I would like to know if there’s any special transition plugin used. The layer above the footage being revealed is broken into pieces. In after effects 6.5 pro, what could be the nearest plugin(effects) that could be used in this manner? I was thinking if card dance could do the trick or, maybe, shatter effect? Any advice? If you could also attach a sample project file, I would really appreciate it. thanks in advance.
    Manny Rellesiva replied 20 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
