Activity › Forums › Adobe Premiere Pro › smaller video file
  • smaller video file
    Posted by Michael Ducey on May 7, 2006 at 5:11 pm
    I have uploaded the 25-min video to my site — https://www.thesecularspirit.com — but it is 668MB, much too big for anyone to download in a reasonable amount of time.
    I saved the file in Windows Media 9 with 2 passes, but I do not need that much image quality.
    What settings do I use to make a much, much smaller file?
    Is there a format that allows the user to view while buffering?
    Erik Pontius replied 20 years, 4 months ago 4 Members · 6 Replies
  • Mike Velte
    May 8, 2006 at 11:39 am
    The Adobe media Encoder offers “Presets” for each Format. Choose “WM9 NTSC 256K Download”…the result will be about 2 MB per minute.
    A 25 minute video will buffer too long on a HTTP server before play begins. Cut the video into thirds or use a “mms” server for true streaming with much less buffer times.
  • Michael Ducey
    May 8, 2006 at 3:07 pm
    Thanks, Mike. That seems to have worked. It’s now 52MB, and on my cable connection it downloads in less than a minute.
    What is an “mms server”?
    I store my web site on an ISP out of the mid-west called “core.com”
    If you want to take a look at the package and comment further, it is located at https://www.thesecularspirit.com
    Thanks again.
    Michael Ducey
  • Steven L. gotz
    May 8, 2006 at 9:04 pm
    The size and quality are fine the way they are. I have editing suggestions, but that would be for a different thread.
    Steven
    http://www.stevengotz.com
  • Michael Ducey
    May 9, 2006 at 2:26 am
    I guess you can tell that I am a novice with Premier Pro. I consider myself lucky to have anything out there at all. I started knowing nothing, and worked my way through with the Total Training DVDs.
    So, recognizing that I am very new to all this, some overall editing suggestions would be welcome.
  • Mike Velte
    May 9, 2006 at 11:25 am
    Your clip buffered for several minutes before playing on my 500+ KBs cable connection…way too long.
    “mms” is an internet protocol for streaming Windows Media Video, requires special server software *Windows Server*. It reduces the buffering times considerably.
  • Erik Pontius
    May 10, 2006 at 8:51 pm
    Most video being stream uses You might expirement with encoding the video using one of the Constant Bitrate Settings “CBR” settings if you intend to stream the video from your site. This will create a file that can be “progressively” downloaded – the video will start play when a sufficient amount has been downloaded, and then it will continue to download as the viewer watches the video. As try changing up the frame rate and audio settings. Lots of streaming web video is using 15fps and lower quality audio settings (32k or less). Often times, websites might make a higher quality version available to download as well…
    As far as the edit goes, I didn’t have time to watch the entire thing, but I found the quick flashes of black frames between cuts to be distracting. Might want to consider moving the clips closer together to avoid gaps between them and then adding a cross dissolve transition or something similiar.
