Activity Forums Adobe After Effects Small size but good quality of render?
  • Small size but good quality of render?
    Posted by Blahtor Magnus on October 13, 2011 at 1:36 am
    Hi, here is the situation:
    I have a 720 HD composition that is 22 seconds long.
    I want to render it to Quicktime MOV, but the catch is that I want the final rendered file to be smaller than 45 MB in size, while the quality of the video must be still above average good (sharp, no visible compression artifacts, etc.
    Is this possible and if yes, what render settings should I use?
    Maria Khan replied 13 years, 4 months ago 5 Members · 8 Replies
  • 8 Replies
  • Angelo Lorenzo
    October 13, 2011 at 1:53 am
    Quicktime MOV isn’t a codec… it’s just a container.
    I would assume that you mean a playback codec like h.264.
    If my math is right 45mb translates to about 16mbps (16,000kpbs, your bitrate).
    If you use AAC audio at 192kbps, you should get really good (not amazing) video at 14,000-15,000kbps.
    Take it with a grain of salt, I did really quick napkin math on it.
    – Angelo Lorenzo
    https://FilmsFor.Us Sell your film and connect with your audience
  • Blahtor Magnus
    October 13, 2011 at 2:08 am
    Hi, thanks for your reply.
    I was just wondering which Render settings would produce best video at low size.
    I will try your trick and see how it goes.
  • Tudor “ted” jelescu
    October 13, 2011 at 6:05 am
    Do not use AE to compress- instead render uncompressed from AE and compress using Adobe Media Encoder. You have plenty of options in there – h264 like it was suggested is a good one. My experience is that h264 comes out looking better if you set keyframes for every frame.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Blahtor Magnus
    October 13, 2011 at 1:14 pm
    Thanks, I will use this mthod for more important projects because it requires more time and I’m always trying to do things as fast as possible.
    I just rendered my current 720 project directly from After Effects, using the settings that Angelo Lorenzo suggested.
    It worked well. File was smaller than 45MB, so I may even up the bitrate to 16,000 kb/s.
  • Walter Soyka
    October 13, 2011 at 1:31 pm
    [Tudor "Ted" Jelescu] “My experience is that h264 comes out looking better if you set keyframes for every frame.”
    This works if you allow a very high data rate.
    If you constrain the data rate, though, it will actually lower quality. Keyframes contain complete picture data, so with a low data rate, the H.264 compressor is forced to heavily compress every single frame. With natural keyframes (or natural with forced keyframes every few seconds), you can get better quality in lower data rates, because the compressor is allowed to spend more bits on the keyframes and fewer bits on the in-between frames.
    I heartily recommend the Matrox H.264 CompressHD card to anyone who does a lot of H.264 compression. It’s a hardware H.264 compressor that gives great results very quickly.
    Walter Soyka
  • Walter Soyka
    October 13, 2011 at 1:36 pm
    [Blahtor Magnus] “Thanks, I will use this mthod for more important projects because it requires more time and I’m always trying to do things as fast as possible.”
    Creating an intermediate file makes a second step for you, but in my experience, it does not add significantly to the total processing time. When rendering directly to a compressed format, AE must first render the uncompressed frame, then compress it, so the math is the same either way. You may save a few seconds on disk access over rendering to an intermediate, but you sacrifice significant control over the encode.
    [Blahtor Magnus] “I just rendered my current 720 project directly from After Effects, using the settings that Angelo Lorenzo suggested. It worked well. File was smaller than 45MB, so I may even up the bitrate to 16,000 kb/s.”
    Rendering directly to H.264 from the AE render queue will not allow you to use multi-pass encoding, which can significantly increase quality and/or lower file size.
    Walter Soyka
  • Blahtor Magnus
    October 14, 2011 at 1:05 am
    Wow, thanks for all the great info, Walter Soyka.
    I guess I am happy with my setup for now but I will know how to do things in the future if there’s need for really super crisp and pristine video quality.
  • Maria Khan
    May 9, 2013 at 6:26 am
    dear all
    i made a video and render with AE, its size was 603mb.. but i cannot upload it in vimeo. then i render it with Wmv in AE, now its size reduced but quality was very poor, these are detail of my H264 AND WMV video
    these information is for h264 i want just 500mb with hd its size made 603
    h264
    item type MPEG-4 MOVIE
    SIZE 603
    video
    length 01:42:22
    frame width 680
    frame height 510
    data rage 689 kbps
    total bitrate 815kbps
    frame rate 30frames/second
    audio
    bitrate 125kbps
    channels 2stereo
    audio sample rate 48khz
    then i render with wmv, but video quality was so bad, detail is that
    video
    length 01:42:23
    frame width 680
    frame height 510
    data rate 341kbps
    total bitrate 421kbps
    audio
    bit rate 80kbps
    channels 2stereo
    audio sample rate 44khz
    size 308
    i dont want high hd video but just it should 480+610, please give me detail what should i do bitrate, in after effects or adobe media encoder
