Small mixer with AGC feature for PEG cable channel feed
Brian Reynolds replied 11 years, 1 month ago 4 Members · 11 Replies
Brian Reynolds
July 12, 2015 at 6:38 amWhat you are needing to do is pad the output signal from +4 (pro level) down to -10 (consumer RCA) level.
So you need a 15db pad to get the units matched correctly, putting in ‘active’ gain controls only add noise and weak links into the chain.
For just a few cents worth of resistors you can get the levels right….
https://www.uneeda-audio.com/pads/
