Activity Forums Adobe After Effects Expressions Small jump in size after time mark is passed
  • Small jump in size after time mark is passed
    Posted by David Cabestany on March 31, 2020 at 9:07 pm
    I’m applying the following expression to generate some scale trails with some layers.
    I need to come as 1,2,3 and then leave 3,2,1.
    This expression sort of works, however when the needle goes past 1 second the 3rd layer (the 2nd trailer) jumps its scale from 100 to 100.8. The layer above does not change.
    I get an expression error warning from 1 second to 2 seconds and then it goes away.
    The expression works despite the error warning except for the .8% jump in size.
    Any help is greatly appreciated
    delay = thisComp.layer("xp").effect("d")("Slider")
    t=time;
    d = delay*thisComp.frameDuration*(index - 1);
    if
    (t<1)
    s=thisComp.layer(6).scale.valueAtTime(time - d)
    if
    (t>2)
    s=thisComp.layer(6).scale.valueAtTime(time + d)
    s;
    Dan Ebberts replied 6 years, 5 months ago 2 Members · 4 Replies
  • Dan Ebberts
    March 31, 2020 at 9:52 pm
    For starters, you don’t define what s is when t is between 1 and 2. I’d set it up like this:
    if (t < 1){
    s = // value when t less than 1
    }else if (t <= 2){
    s = // value when t between 1 and 2
    }else{
    s = // value when t > 2
    s
    I’m not sure that’s the only issue, but it should help…
    Dan
  • David Cabestany
    March 31, 2020 at 10:41 pm
    Thanks Dan, that helped, but the expression seems convoluted, could a while statement work in here or it will crash the program?
  • Dan Ebberts
    March 31, 2020 at 10:48 pm
    I don’t think while will help, but what exactly are you trying to do?
    Dan
  • Dan Ebberts
    March 31, 2020 at 11:09 pm
    One problem you might be having is that there will be discontinuities at 1 and 2 seconds, where the amount of delay changes abruptly. You might want to ease through those changes with something like this (not tested at all):
    easeTime = .25;
    delay = thisComp.layer("xp").effect("d")("Slider");
    t=time;
    if (t < 2){
    dly = ease(t,1-easeTime,1,-d,0);
    }else{
    dly = ease(t,2,2+easeTime,0,d);
    thisComp.layer(6).scale.valueAtTime(time + dly)
    Dan
