Activity Forums Adobe After Effects small file size for alpha channel graphics
  • small file size for alpha channel graphics
    Posted by Jonathan Hudson on February 12, 2008 at 11:59 pm
    i am wondering what the best way to export an animation with an alpha channel is if i’m trying to keep the size down as much as possible. Normally when i export with alpha channel i use the “Animation” codec which seems to be bigger because its uncompressed. it needs to be 1080p30. so i guess i’m asking for export settings and codec settings.
    i am using after effects cs3 on a mac pro os 10.4.9
    thanks
    jonathan
    Darby Edelen replied 18 years, 7 months ago 5 Members · 4 Replies
  • Steve Roberts
    February 13, 2008 at 1:25 pm
    Did you try using a lower quality setting with the Animation codec? (under “options” in the Output Module)
  • Justin Vaillancourt
    February 13, 2008 at 3:26 pm
    PNG allows for an alpha channel and correct me if I’m wrong, but I think it’s about 1/4 the size.
    Takes forever to render though!
  • David Bogie
    February 13, 2008 at 5:11 pm
    In the olden days, we used to export a color movie and an alpha-only monochrome movie. The monochrome was used to feed the track matte feature in another application. the codecs for these two movies could be anything.
    bogiesan
  • Darby Edelen
    February 13, 2008 at 6:56 pm
    [david bogie] “In the olden days, we used to export a color movie and an alpha-only monochrome movie.”
    As an addendum to that thought, the Animation codec at 100% quality is lossless but it is not uncompressed. It uses a form of run line encoding to significantly compress areas of solid color without losing any data. Since alpha channels are generally large areas of black or white (unless you’re dealing with an alpha of a snow storm, yikes!) you can generally get very decent compression of just an alpha channel from the Animation codec at 100% quality.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
