Activity Forums DaVinci Resolve Small dots on image when exporting raw
  • Small dots on image when exporting raw
    Posted by Samuel Chamalet on October 24, 2015 at 10:31 pm
    Hello everyone !
    In order to prepare for a future shooting, I made some tests shots using Magic Lantern MLV format, to test the workflow and grading. Here’s my problem : After quickly grading and exporting 422 Prores HQ, I noticed on every frame, some small dots (which seem to be slightly coloured) have appeared in the center of the image :
    Zoomed in here :
    I also have other issues, on some shots the highlights are flickering, and lastly on one shot, every other frame is like this :
    Is this Resolve related ? (I know my graphic card is not supported – Intel Iris Pro 1536 Mo on a 2014 macbook pro-) Could this may be because of the MLV ? (Once again, I’ve been shooting these on a pretty cheap Canon DSLR -T3i- so I don’t know…)
    Cheers,
    Vincent.
    Nikola Mrdalj replied 10 years, 11 months ago 3 Members · 4 Replies
  • Tero Ahlfors
    October 25, 2015 at 7:47 am
    I would not trust Magic Lantern with anything. I’ve yet to see trouble free footage from that mess.
  • Nikola Mrdalj
    October 25, 2015 at 8:32 pm
    what software have you used to convert the mlvs to dngs? could be the problem lays there.
    Film & Adverts Colorist, Media+ Belgrade
    https://www.imdb.com/name/nm3829270/?ref_=fn_al_nm_1
  • Samuel Chamalet
    October 25, 2015 at 8:50 pm
    Yes, that could be the issue… I’m using MLVMystic, any known problem with it ?
  • Nikola Mrdalj
    October 25, 2015 at 9:28 pm
    try using this one:
    https://www.magiclantern.fm/forum/index.php?topic=9560.0
    you’ll find the tutorial also on the linked page. it has never failed me 🙂
    also, if that doesn’t fix the problem, try checking if you have “force sizing to highest quality” and “force debayer resolution to highest quality” in deliver tab, also, try exporting the DPX sequence instead of prores, could be that your quicktime encoder is bugged..
