Activity › Forums › Adobe After Effects › Small compression in QuickTime
  • Small compression in QuickTime
    Posted by Barak Ziv on June 29, 2009 at 2:14 pm
    I’m using AVI compression with Divx codec in my work out of AE and I get really good results- substantially small files without a significant lost in quality. I’m trying to find a similar setting with Quick Time but couldn’t find any. The closet one was Quick Time H.264 which isn’t as small and the color output is incorrect. When I tried the key frame every X frame option, the render crashes.
    Any suggestions?
    Barak Ziv replied 17 years, 3 months ago 3 Members · 3 Replies
  • David Bogie
    June 29, 2009 at 2:32 pm
    Render out of After Effects to a good quality codec and then bring the rendered movie into a compression/transcoding system, separate from AE.
    bogiesan
  • Kevin Camp
    June 29, 2009 at 2:59 pm
    [david bogie] “bring the rendered movie into a compression/transcoding system”
    streamclip is free, multiplatform and do multi-pass encoding (smaller files, better quality).
    if you have cs4, you should have adobe media encoder which will do virtually the same (it can actually load the ae project and render from that, but i don’t know how that compares to having an actual render to encode from).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Barak Ziv
    June 29, 2009 at 4:56 pm
    Thanks, the options sound good and would work for some of the projects.
    However, I’m still looking for a way do work it out in After Effects, I work with bulk amounts of short shots, each 50-100 frames long. I will try these methods though.
