Activity Forums Boris FX Particle Illusion small bug report
  • small bug report
    Posted by Vincent Vacher on May 21, 2006 at 11:53 am
    Hello,
    Just to report a small bug: if you move a video file (used as background in a project) to an other folder when you open the poject PI crashes. A ‘file not found’ message would be better.
    Just for the next version… i hope soon. Thanks.
    Vincent
    Trelawney replied 20 years, 4 months ago 4 Members · 4 Replies
  • Alan Lorence
    May 21, 2006 at 12:06 pm
    What exact version number are you running (check the “About…” box) and what OS?
    Alan.
    wondertouch
  • Vincent Vacher
    May 22, 2006 at 6:04 pm
    Hello Alan,
    I use PI 3.0 (3.0.1a 01/29/2004) on Windows platform.
    Ps: As soon i replace file on its original place PI open my project.
    Regards.
    VINCENT
  • Jose Burgos
    May 23, 2006 at 1:49 pm
    I do not have that problem with the same version of pi3.
    What I get is a file window asking me where the file is to load it.
    Jose Burgos
  • Trelawney
    May 24, 2006 at 3:19 am
    Hi there
    I’ve had this problem also – but mainly from when i’ve opened a IP3 by double-clicking on it to open.
    If a texture/file is missing and I OK to search for it, when I select it in the file browser – PI3 just closes.
    This doesn’t seem to happen (as often) if I open PI3 first, then the IP3 file and then search for any files in the default location.
    As an aside – I also get a Crash (Runtime error – abnormal program termination) in pIllusionRender if I select the AVI Options button. Does this happen to anyone else?
    Kind regards
