Activity Forums Apple Final Cut Pro Legacy Sluggish Timeline in FCP 6.0
  • Sluggish Timeline in FCP 6.0
    Posted by Chris Bryan on July 16, 2008 at 4:16 pm
    Hello,
    I”m running into an issue editing footage in FCP 6. Viewing edits in the timeline is extremely sluggish and sometimes unresponsive. This happens with two types of footage:
    Quicktime: 960X540 uncompressed
    WMV – any size.
    The exported footage plays fine. It’s just such a pain to hit play and wait 5-10 seconds for the timeline to start playing. Is there a setting I need to adjust? Do I need to fix my FCP preferences? Any help is much appreciated!
    Chris Bryan replied 18 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • Jerry Hofmann
    July 16, 2008 at 5:20 pm
    Post your Mac’s configuration. CPU, RAM, OS, QT… and how many edits are in this sequence.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Arnie Schlissel
    July 16, 2008 at 6:55 pm
    [Chris Bryan] “Quicktime: 960X540 uncompressed”
    That’s not a standard size for any film or video use, and is not native to any format that FCP supports.
    [Chris Bryan] “WMV – any size.”
    WMV is not really a supported format for FCP. You should try to convert those to some standard size QT file.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Chris Bryan
    July 16, 2008 at 7:01 pm
    I’m running FCP 6 on an Imac
    2.4 ghz intl core 2 duo
    2 gb ram.
    960×540 is commonly used on the web for “hd” quality videos, it’s half resolution of 1920×1080.
    My understanding is that FCP supports wmv use. I know it’s not the best source to use, but that’s what the client gave me. Converting the wmv source file to quicktime will add another layer of encoding, and I’d rather not do that.
    I realized that I had a sequence with both .avi and .wmv in it. It seems that mixing the two formats was most of what was making the playback slugggish.
  • Mark Maness
    July 16, 2008 at 9:14 pm
    What is the original codecs used?
    I ask because if the video is already half scale – another compression isn’t going to hurt it much if you use something like ProRes422.
    FCP doesn’t play well with WMV and AVI files. They can be made to import but not good for editing entirely. Convert to something more friendly and every will run much better.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • David Bogie
    July 16, 2008 at 10:19 pm
    [Chris Bryan] “960×540 is commonly used on the web for “hd” quality videos, it’s half resolution of 1920×1080. “
    You shouldn’t be doing your scaling in FCP. work in the native format and do your frame conversions at the output stage using Compressor or some other transocder.
    [Chris Bryan] “My understanding is that FCP supports wmv use. I know it’s not the best source to use, but that’s what the client gave me. Converting the wmv source file to quicktime will add another layer of encoding, and I’d rather not do that. “
    You were misinformed. QT can transcode WMV on the fly with a plugin from Flip4Mac but it is not recommended that you mix formats in a timeline and expect realtime performance, too much computation happening.
    The marketing hype behind the open-timeline capabilities of FCP are totally dependent on the speed of your machine. For most of us, it’s easier to convert all weird footage to a common format for assembly, even if we have to recapture or uprez later.
    [Chris Bryan] “I realized that I had a sequence with both .avi and .wmv in it. It seems that mixing the two formats was most of what was making the playback slugggish.
    Lots of things can impact your timeline performance including stuff you can’t see or find. Sometimes a simple restart will fix it, sometimes you need more in the way of help.
    bogiesan
  • Jerry Hofmann
    July 17, 2008 at 8:29 pm
    Ditto… don’t resize until the last.
    Jerry
  • Chris Bryan
    July 17, 2008 at 8:46 pm
    Thanks for all the advice, but I think my point is being missed. I am editing footage that is from the web. So my source footage is 960×540. There is no scaling being done in fcp. I work with a ton of footage from the web so it is always in abnormal formats. For me there is no getting around that. My initial question was asking if there is some setting I should look at changing within final cut so that it doesn’t have to work so hard to play the footage back within the timeline?
    In a perfect world all footage would be optimized for use in FCP, but that’s not the case.
    My issue was resolved by not mixing formats within one timeline.
