Activity Forums VEGAS Pro Sluggish Hard Drive
  • Sluggish Hard Drive
    Posted by Roger Bansemer on December 10, 2012 at 12:55 pm
    I have a hard drive that is very slow to respond. When renaming a file, it takes longer than usual and when I open the directory to see all the folders it also takes time.
    Is this a sign of a hard drive going bad?
    Roger Bansemer
    Roger Bansemer replied 13 years, 9 months ago 8 Members · 8 Replies
  • 8 Replies
  • Steve Rhoden
    December 10, 2012 at 1:58 pm
    You probably need to Defragment it.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Mike Kujbida
    December 10, 2012 at 2:01 pm
    It could also be a case of the drive being close to its capacity.
    In either case, hard drives are very cheap these days so buy another one, just in case, and back this one up before doing anything to it.
  • Mark Barton
    December 10, 2012 at 4:16 pm
    Are there thousands of files in a single directory? Sometimes the overhead of the operating system maintaining the directory entries for a large directory can cause this type of sluggishness. That is usually coupled with fragmentation of the files (scattered throughout the drive rather than organized neatly in contiguous sections).
  • Aleksey Tarasov
    December 10, 2012 at 4:22 pm
    Also, your antivirus software can scan files in the background…
    Vegasaur.com – Plugins for Sony Vegas Pro
  • Tyson Onaga
    December 10, 2012 at 10:56 pm
    You could run Process Explorer. R-click on a column header, choose Select Columns. Dialog will appear:
    On the Process Performance tab, enable I/O Reads and I/O Writes.
    You can now sort by these columns in main view and thus see which apps are causing the most I/O traffic. Hopefully, they’re not problematic.
  • Stephen Mann
    December 11, 2012 at 2:47 am
    Try turning off indexing for that drive.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Phil Seymour
    December 11, 2012 at 3:37 am
    Question is, has it become slow suddenly, over a period of time, or has always been slow. Is it a data drive or your main system drive?
    A near capacity drive will slow down especially if fragmentation is bad as mentioned in previous posts.
    Is it a “Green” drive… they can go off for a low-power snooze when not accessed for a while.
    A bit of Googling will find programs that test your HD’s efficiency – but make sure it is from a reputable software company or HD maker.
    Windows 7 Pro64, 16GB RAM, SSD boot drive, GTX 570 Graphics, Vegas Pro 12
  • Roger Bansemer
    December 11, 2012 at 4:40 pm
    Thanks everyone for all the tips on the questionable hard drive.
    It’s not very full so that isn’t an issue. It’s be defragmented also. In fact Windows seems to keep them defragmented all the time.
    I can’t really say if it’s been over time that it’s acting very slow but it just doesn’t seem to access files as quickly as my other drives.
    I’ve never heard of the “indexing”. What is that?
    I’ll also check out the “performance tab”
    Roger Bansemer
