Activity Forums Adobe Premiere Pro SLR H264 Footage looks bad in premier
  • SLR H264 Footage looks bad in premier
    Posted by Chandra on September 25, 2012 at 4:46 pm
    We shot footage on the Canon 5D MarkIII using the H264 All-i codec.
    We took the footage directly into Premier to start cutting. We recently switched from FCP to Premier so we could save time and not have to encode all our footage to prores first.
    We have found the footage looks terrible after adding some minor color effects (B&W / brightness/ contrast). The H264 files look very pixelated and like a You tube video.
    We went back and did a Prores test. We converted the file to prores 422 and replaced the footage in premier and it looks much better. The whole point of using premier was so we didn’t have to do this.
    Has anyone else had this problem? Is there a setting or something we are doing wrong? Any advice would be great!
    Here is a link to see the comparison shots (you’ll have to download individually)
    https://cookepictures.com/clients/h264vsprores/
    Gary Alan replied 12 years, 11 months ago 9 Members · 13 Replies
  • 13 Replies
  • Clay Coleman
    September 25, 2012 at 5:07 pm
    You are previewing in full resolution, yes?
  • Chandra
    September 25, 2012 at 5:11 pm
    Yes, we have actually been doing tests exporting out of Premier also. The only way we have been able to get the footage to look good it to convert the original clips to prores and bring it into premier that way. It will take days to convert all the footage.
  • Chris Borjis
    September 25, 2012 at 5:15 pm
    wow, that doesn’t make any sense.
    what sequence setting/size are you using?
    I use AVC 100 for everything, never seen that problem.
  • Chris Tompkins
    September 25, 2012 at 5:31 pm
    APP uses “preview” files for editing, they do not show your final quality.
    Exporting sequence show yield your highest quality, depending on what you’re compressing to.
    Sequence matches footage specs?
    Chris Tompkins
    Video Atlanta LLC
  • Petros Kolyvas
    September 25, 2012 at 6:28 pm
    You can set the preview files to higher-quality if required under your sequence settings. You could, for example, create 10-bit ProRes 422 HQ preview files if that suited you.
    There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger
  • Craig Harris
    September 25, 2012 at 8:23 pm
    Doesn’t all H264 Canon footage look that way when you apply changes to the contrast and colour?
  • Chris Borjis
    September 25, 2012 at 10:11 pm
    [Craig Harris] “Doesn’t all H264 Canon footage look that way when you apply changes to the contrast and colour?”
    thats a very valid point.
    DSLR falls apart when you push it hard.
  • Clay Coleman
    September 26, 2012 at 9:48 am
    You’re doing something basically wrong.
    You should be able to:
    1. go to the media tab, navigate to your media drive and see all your files.
    2. Then double click on one to open it in the viewer (or right click to import and then double click to open), making sure the viewer window is set to playback at full resolution (just right click the viewer window for the list of view options).
    And that’s it. Converting to ProRes will achieve other things, but will not improve the quality. If you want to edit straight away with the DSLR files, it shouild be no problem whatsoever.
    Or, using the transcode approach, do the previewing, selecting and transcoding in DaVinci Resolve 9. This has a number of added advantages including being able to keep original filenames and source timecode if need be.
  • Brent Dunn
    September 26, 2012 at 4:42 pm
    What are your settings when exporting. If you are exporting sequence settings, you may already have the wrong sequence settings to start. Customize your export settings to make sure you have the quality.
    Pushing the H.264 files can cause problems too.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro Tower, Quad Core,
    with Final Cut Studio
    HP i7 Quad laptop
    Adobe CS-5 Production Suite
  • Craig Harris
    September 28, 2012 at 6:53 pm
    [Brent Dunn] “Pushing the H.264 files can cause problems too.”
    The 5D footage is incredibly tricky to work with.
    I colour grade a lot of projects and always cringe when I hear a project was shot with the 5D. There are time consuming ways to improve how 5D media responds, but time isn’t usually an option.
    Craig
