Activity Forums DSLR Video SLR d500
  • SLR d500
    Posted by Mark Dannunzio on December 9, 2010 at 2:25 pm
    Hello,
    I just purchased a Nikon D5000. All of the video settings are set for me to shoot 720P. If I want to edit the HD footage in my PC, how do I transfer the footage so it stays in it’s native HD format? Does it transfer over the USB? Or do I need to purchase a HDMI to go out from the D5000 into my computer?
    Much appreciated
    Mark
    Mark Dannunzio
    Brent Dunn replied 15 years, 9 months ago 3 Members · 3 Replies
  • Micah Mcdowell
    December 9, 2010 at 4:45 pm
    Yes, you transfer the files over USB (or take the card out of the camera and use a dedicated card reader… they’re usually faster).
    There would be no benefit to capturing files you’ve already shot to the memory card via HDMI. Unless, you record the uncompressed HDMI signal to a higher-bitrate device or capture card live while you shoot; you might gain a bit of quality that way. You should check if the D5000 even outputs via HDMI at full-res with no display overlays while shooting live; even if Nikon says it does, it may not be the full HD signal. I’m a Canon guy as of late so couldn’t tell you.
  • Mark Dannunzio
    December 9, 2010 at 5:19 pm
    That’s what I thought, must be my computer then. The video looks horrible! Def. not HD. Quicktime will play HD video without going Pro correct?
    Mark
    Mark Dannunzio
  • Brent Dunn
    December 10, 2010 at 3:43 pm
    Just copy the media into a folder on your computer. If you are using Premier, you can import the media as is and edit away. Make sure you copy all of the card folders, as some have important data that support the media.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1, V1U
    Canon 5D Mark II
    Canon 7D
    Mac Pro Tower, Quad Core,
    with Final Cut Studio
    HP i7 Quad laptop
    Adobe CS-5 Production Suite
