Activity Forums DaVinci Resolve Slowmotion in resolve
  • Slowmotion in resolve
    Posted by Daniel Albers on February 11, 2013 at 9:23 pm
    So I am importing an XML file into Resolve.
    Everything works fine except the clips i slowed down in premiere..
    It simply doesn’t load them.
    Is it just not possible or am i doing something wrong?
    Kind regards
    -EDIT
    Im working in 50Fps.. dont know if this is what causes the problem?
    Cris Cazor replied 12 years, 8 months ago 3 Members · 4 Replies
  • Juan Salvo
    February 12, 2013 at 1:31 am
    Welcome to prp XML. Run the XML through fcp to clean up. Or better yet: remove the speed effect in prp, round trip to resolve and then add the effect back in.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Daniel Albers
    February 12, 2013 at 9:48 am
    Thanks for the answer.
    I am running in premiere pro, just to clear things up.
    I was just hoping i wouldn’t have to delete any effects but i suppose davinci simply doesn’t handle it?
  • Juan Salvo
    February 12, 2013 at 2:25 pm
    It’s not that resolve doesn’t handle it’s the prp doesn’t properly explain it in the XML. Speed changes coming from fcp7 tend to work ok. But not from prp. That’s why I said to take the XML through fcp7.
  • Cris Cazor
    January 14, 2014 at 2:01 am
    Hi Juan,
    So, would it be easier if I exported the XML at 100% speed from PPro to fcp and then on fcp do the slomo?, then export another xml and open on resolve?
