Activity Forums Apple Final Cut Pro Legacy Slowing down 24p footage?
  • Slowing down 24p footage?
    Posted by Annaël Beauchemin on May 15, 2006 at 7:10 pm
    Has anyone found a efficient workflow or plugin to slow down 24p footage with pulldown in a 29.97 timeline without looking awful?
    I’ve tried quite a few demo versions of pluggins and they are either a pain to use, very slow or then they make media recapture impossible.
    So far i’ve been juggling the clips between cinema tools and FCP, but this is a big waste of time and makes media management more complex.
    why isn’t there a retimer pluggin that can remove pulldown auomaticaly, do the speed change, and then add the pulldown back? You know, like in Avid MC/Symphony/DS…
    Annaël Beauchemin replied 20 years, 4 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    May 15, 2006 at 9:39 pm
    Boris’ Contiuum contains a dandy filter for this “optical flow” is the filter’s name… also there’s wonderful software from ReVision FX: https://www.revisionfx.com/rstwixtor.htm Either filter uses optical flow technology, and actually creates new frames interpolated from the old where FCP’s slo mo simply adds the same frames again…
    Jerry
  • Annaël Beauchemin
    May 17, 2006 at 3:27 pm
    Twixtor does not seem to remove the pulldown before slowing down, so the movement is still jerky. They also have a pulldown remover plugin, but either it cannot be used in conjunction with Twixtor, or then i’m missing something..
    I’ll look into a demo Boris optical flow, this one escaped my list!
    thanx
