Activity Forums Maxon Cinema 4D Slowing a noise shader/displacer to a stop
  • Slowing a noise shader/displacer to a stop
    Posted by Cassius Marques on November 7, 2013 at 8:33 pm
    Hey guys, I’m using a noise in the shader tab of a displacer modifier. I used the Animation Speed option but now I need the evolution effect to slow down to a complete stop. Problem is that parameter can’t be keyframed since it flickers like hell. I’m gessing it’s because that controls evolution over time.
    Any workarounds other than duplicating the modifier without animation speed and transitioning between them? (not ideal and troublesome in my current scene state).
    Cassius Marques replied 12 years, 10 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    November 7, 2013 at 11:49 pm
    I don’t see flickering here, but what I do see is that instead of just slowing down, the noise actually reverses direction, which is odd.
    The only thing I can think to do is to bake the animation to PLA and then use a time track to slow/stop it.
  • Brian Jones
    November 8, 2013 at 3:54 am
    no flickering here either, though, like Adam I’ll bet, I’m looking at a noise in the color channel. I have found that the noise stops always at the 1/2 way point between whatever value you start with and zero then apparently runs backward to zero. If you end at a value that is exactly 1/2 of what you started at it stops like you want. Perhaps it’s a harmonic thing but it doesn’t seem to matter what value you start at for Animation Speed it will stop at the 1/2 value, regardless of the noise type.
  • Cassius Marques
    November 8, 2013 at 11:16 am
    “flicker” was a bad wording. It seemed so because I was trying to slow to a halt after a lot of frames passed. When you keyframe it to zero it backwards all the time it evolved until that point, it got so quick it seemed to flicker.
    Anyway changing values or reducing to half the start won’t help. It goes backwards then continues to animate.
    thanks.
  • Cassius Marques
    November 8, 2013 at 11:23 am
    Yeah, baking would be one way to do it that I haven’t considered. But it seems just duplicating/transitioning to another displacer will be quicker/easier. I’m already time tracking everything else though.
    I guess I was wishing for some hidden evolution property on them. =]
    Thanks.
