Activity › Forums › Apple Motion › Slowdown playback speed of timeline?
  • Slowdown playback speed of timeline?
    Posted by Jeremy Peplow on September 7, 2010 at 4:24 pm
    Hello All,
    I’m trying to use the “record on the fly” feature of motion to animates an object. For example, I have an object that I need to animate on a persons hand for a clip thats about 10 seconds in duration. I know I can arrow to each frame and add a keyframe but I would like to just hit record and then play and animate on the fly. The problem when I try this technique is the playback speed is way too fast. Is there a way to play my timeline much slower? I know I can slow the clip down but that just screws up all the keyframes when I set the clip back to 100%. Seems like an easy thing to do but I can’t figure out how to do it anywhere.
    Jeremy
    Sacha Thomas replied 16 years ago 2 Members · 1 Reply
  • Sacha Thomas
    September 7, 2010 at 7:54 pm
    It sounds like the motion tracking behaviors would be of use. It would at least allow you to focus on the animation rather than both animation and position. I am not sure what you are trying to do but that might work for you. Good luck.
