Activity › Forums › Adobe Premiere Pro › Slow timeline export in Premiere CS6
Posted by Liz Parham on April 28, 2014 at 7:29 pmNew to Premiere, editing a timeline in ProRes HQ. My timeline shows up as yellow, but I was told to ignore this?
I tried to export an interview to transcribe, checked the use render preview box, export is taking about 30-45 min. It would take about 3 min using FCP–export quicktime.
Any advice? I usually do small exports every day, so any suggested way to speed them up would be very helpful. Or might just switch back to FCP.
Using a mac mini, 8 GB, i7
Liz Parham replied 12 years, 5 months ago 3 Members · 10 Replies -
Tim Kolb
April 28, 2014 at 8:05 pmDepending on what version of Premiere Pro you’re using, there should be a ProRes sequence preset?
In CC, ProRes on a Mac should handle very similarly to FCP if the sequence and export are set up correctly.
TimK,
Director, Consultant
Kolb Productions,Adobe Certified Instructor
Liz Parham
April 28, 2014 at 8:27 pmSry, editing in Premiere Pro CS6 using the DSLR sequence preset.
Tim Kolb
April 28, 2014 at 8:54 pmKeep in mind that in FCP you’d have spent the time up front to transcode -all- the DSLR to ProRes ahead of time…so the export to ProRes doesn’t take long.
In order to compare render times, you’d have to take the time you spent exporting in Premiere Pro, and compare that to the short period you spent exporting in FCP -AND- the time spent transcoding the DSLR media to ProRes before you even begin editing in FCP.
TimK,
Liz Parham
April 28, 2014 at 9:08 pmTrue, but I also transcoded everything to HQ via mpeg streamclip ahead of time in order to edit with Premiere/FCP. I know you can edit h264 in PPro, but we found it easier to just have the HQ files already so we would’t have to deal with an offline/online workflow.
Liz Parham
April 28, 2014 at 9:15 pmPS I also used PluralEyes, which exports its own xml into Premiere. I assumed those sequences would match the sequence settings set in Premiere, but maybe not? Oye, my problems usually start at PluralEyes.
Tim Kolb
April 28, 2014 at 9:27 pmEditing native isn’t “offline/online”…it’s simply leaving the media transcode to the end, which saves time (and drive space).
Why are you using the DSLR sequence setting when you’re editing Prores?
TimK,
Tim Kolb
April 28, 2014 at 9:29 pmI don’t use Plural Eyes (PPro CC actually has a similar function inside the software) so I don’t have much insight into that workflow I’m afraid…
Since you’re transcoding all that footage anyway, why wouldn’t you simply use the secondary audio as the audio for the transcoded file?
TimK,
Paul Neumann
April 29, 2014 at 2:59 amHere’s what you should do:
https://blogs.adobe.com/VideoRoad/2011/08/a-prores-workflow-end-to-end.html
Then the “Use Previews” function will actually do something for you.
Liz Parham
April 29, 2014 at 3:27 pmThanks, Paul.
I did adjust the dslr sequence setting to match HQ codec, but it seems I didn’t for the output settings.
Plural eyes still exports a sequence that isn’t the right setting, but I can copy the sequence and paste into one that is correct.
Liz Parham
April 29, 2014 at 3:43 pmre: Tim
Sry, my brain thinks editing native is “offline/online” if we have to media manage/transcode the files to HQ in the end. Because MPEG streamclip erases TC, I worry that won’t work in premiere as it didn’t work in FCP on our last film after editing in Proxy with no TC. Already looked into QTchange to add timecode back in, but I was getting error messages in PluralEyes. Once again, all troubles lead to PluralEyes.
We also like to retain the camera audio in all of our clips since we’re mostly editing documentaries and sometimes the camera audio is better than our secondary audio.
