Activity › Forums › Adobe Premiere Pro › Slow response on audio effect adjustments.
  • Slow response on audio effect adjustments.
    Posted by Xavier De champs on November 1, 2005 at 3:57 pm
    When I apply a audio effects. For example the Compressor. Why does premiere respond very slowly when I crank the buttons up and down? This is also anoying when I use the EQ effect. Does premiere really do any calculations when I crank these buttons? Should only be calculating when I play.
    What about you guys, do you have the same problem? (I
    Xavier De champs replied 20 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
