Activity Forums Apple Final Cut Pro Legacy slow rendering – suggestions?
  • slow rendering – suggestions?
    Posted by Dan Veltri on December 31, 2012 at 8:55 pm
    Hi Folks,
    Sorry for the long post here, but I know that y’all can’t give me any advice unless you know all the details. So here’s the situation:
    I’m using FCP 7.0.3. I produce short educational media pieces and do a lot of subtitling. I’ve been shooting with a GH2 and loving it, and always edit the AVCHD footage using ProResLT. The problem is every time I add a new subtitle (on the same video track) I need to render it. Here are my system details:
    Running Snow Leopard 10.6.8. I use a lot of After Effects and just joined Adobe’s Cloud Program…thinking about slowly migrating to using Premiere Pro.
    My questions:
    1- how can I avoid these constant renders? Do I need a new graphics card? Heard lots of good things about the Quadro 4000. Thoughts?
    2 – the Maxx Digital RAID is only using the FireWire 800 connection now. At the time I purchased the RAID, the e-SATA card was not working with my system. Would solving that issue and using the e-SATA connection solve my speed issues?
    Thanks in advance for your time – and Happy New Year!
    –Dan Veltri
    Producer
    Treehouse Video
    Hardware Overview:
    Model Name: Mac Pro
    Model Identifier: MacPro4,1
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 2.66 GHz
    Number Of Processors: 1
    Total Number Of Cores: 4
    L2 Cache (per core): 256 KB
    L3 Cache: 8 MB
    Memory: 8 GB
    Processor Interconnect Speed: 4.8 GT/s
    Boot ROM Version: MP41.0081.B07
    SMC Version (system): 1.39f5
    SMC Version (processor tray): 1.39f5
    Serial Number (system): H09430V94PD
    Serial Number (processor tray): J5939016X4MFE
    Hardware UUID: A85D70BD-3D1C-511D-ACF5-0FC15765E93D
    ATI Radeon HD 4870:
    Chipset Model: ATI Radeon HD 4870
    Type: GPU
    Bus: PCIe
    Slot: Slot-1
    PCIe Lane Width: x16
    VRAM (Total): 512 MB
    Vendor: ATI (0x1002)
    Device ID: 0x9440
    Revision ID: 0x0000
    ROM Revision: 113-B7710C-176
    EFI Driver Version: 01.00.318
    Displays:
    LCD200VX:
    Resolution: 1344 x 1008 @ 60 Hz
    Pixel Depth: 32-Bit Color (ARGB8888)
    Display Serial Number: 48101067QA
    Mirror: Off
    Online: Yes
    Rotation: Supported
    LCD200VX:
    Display Serial Number: 4X103203QA
    Main Display: Yes
    Mirror: Off
    Online: Yes
    Rotation: Supported
    FireWire Bus:
    Maximum Speed: Up to 800 Mb/sec
    Built-in Hub:
    Connection Speed: Up to 800 Mb/sec
    OXFORD IDE Device 1:
    Manufacturer: Oxford Semiconductor Ltd
    Model: 0x0
    GUID: 0x30E002E0A08890
    Sub-units:
    OXFORD IDE Device 1 Unit:
    Unit Software Version: 0x10483
    Unit Spec ID: 0x609E
    Firmware Revision: 0x100
    Product Revision Level: 0
    Sub-units:
    OXFORD IDE Device 1 SBP-LUN:
    Capacity: 3 TB (3,000,461,058,048 bytes)
    Removable Media: Yes
    BSD Name: disk2
    Partition Map Type: GPT (GUID Partition Table)
    S.M.A.R.T. status: Not Supported
    Volumes:
    Capacity: 209.7 MB (209,715,200 bytes)
    Writable: Yes
    BSD Name: disk2s1
    THMaxx1:
    Capacity: 1 TB (1,000,153,686,016 bytes)
    Available: 571 GB (570,997,809,152 bytes)
    Writable: Yes
    File System: HFS+
    BSD Name: disk2s2
    Mount Point: /Volumes/THMaxx1
    THMaxx2:
    Available: 582.93 GB (582,928,793,600 bytes)
    Writable: Yes
    File System: Journaled HFS+
    BSD Name: disk2s3
    Mount Point: /Volumes/THMaxx2
    THMaxx3:
    Capacity: 999.54 GB (999,541,276,672 bytes)
    Available: 443.74 GB (443,739,410,432 bytes)
    Writable: Yes
    BSD Name: disk2s4
    Mount Point: /Volumes/THMaxx3
    Jeff Meyer replied 13 years, 8 months ago 3 Members · 2 Replies
  • Mark Suszko
    December 31, 2012 at 10:36 pm
    My first guess is that your sequence settings and import settings don’t agree. It happens. Compare them side by side using “get info”.
    Happy New Year, hope that fixes it.
  • Jeff Meyer
    January 1, 2013 at 10:21 am
    Do you have unlimited RT turned on?
