Activity › Forums › VEGAS Pro › Slow Rendering in Sony Vegas Pro 11
  • Slow Rendering in Sony Vegas Pro 11
    Posted by Martin Stanesby on October 10, 2013 at 11:08 am
    When rendering an old movie in 4:3 (about 1:45mins in length)the rendering is about 6 hours….. is this normal?
    Here are the settings i’m using:
    Template: PAL DV (720 x 576 aspect ratio, 25fps)
    pixel ratio: 1.0926(PAL DV)
    pixel format: 8-bit
    Full-resolution rendering quality: Good
    The rendering settings are:
    MainConcept MPEG-2 – DVD Architect PAL video Stream
    25fps, 720 x 576 lowerfield first, YUV, 6 mbps, pixel aspect ration: 1093.
    My PC specs are:
    CPU – Intel COre i5 3570k 3.40ghz
    RAM: 8GB
    64 bit
    2TB hard drive (with plenty of space).
    Sony Vegas Pro 11 64bit
    Any help appreciated.
    thank you
    Martin
    Martin Stanesby replied 12 years, 11 months ago 3 Members · 3 Replies
  • Stephen Mann
    October 10, 2013 at 2:50 pm
    is this normal?
    Probably.
    There are a thousand (OK, just a few dozen) reasons that a render can be slow. But any F/X can make rendering slow because the render engine has to composite the F/X on each affected frame. Some F/X, such as colorizing or opacity effect every pixel on every frame and will take considerably longer to render than a video with cuts only.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Mate Perić
    October 10, 2013 at 4:15 pm
    try to remove some effects and see if ti will render faster
  • Martin Stanesby
    October 10, 2013 at 9:25 pm
    Thanks Guys, That was the issue, I was hoping to clean it up a bit but just a couple of effects like reducing noise caused the rendering to increase massively. I fI had the time it would be no probs.
    Thanks again.
    Martin
