Activity Forums Adobe Premiere Pro slow rendering
  • slow rendering
    Posted by Bodybuildingbs on July 22, 2005 at 5:17 am
    I wanted to render the first 30 minutes of my video project in premiere and it started off with 50 minutes…when I returned an hour later it said..and I am being serious….2 months? Huh?
    Premiere was the only thing running
    3.00 gigahertz Intel Pentium 4
    16 kilobyte primary memory cache
    1024 kilobyte secondary memory cache
    Board: ASUSTeK Computer Inc. P4P800-E Rev 1.xx
    2.5 GB of memory//////
    No offense but 2 months seems a little long…..?
    Mike Velte replied 21 years, 2 months ago 3 Members · 4 Replies
  • Steven L. gotz
    July 22, 2005 at 5:50 am
    What effects did you apply?
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Bodybuildingbs
    July 22, 2005 at 5:15 pm
    Well the audio was massaged in audition and reimported…I have some 2d particle stuff which was rendered in Particle Illusion and exported back out…have some dissolves..and some stock footage….
  • Steven L. gotz
    July 22, 2005 at 8:46 pm
    Rendered in Particle Illusion could be a problem. And is the stock footage standard DV AVI?
    Steven
  • Mike Velte
    July 22, 2005 at 8:52 pm
    The Particle Illusion video resolution may not match your project settings, but still should not take very long….use the work area bar to isolate half your project and note projected render times, then use the half and half again ritual to isolate the problem child.
