Activity › Forums › DaVinci Resolve › Slow render: 1fps
  • Slow render: 1fps
    Posted by Charles Ford on April 29, 2014 at 1:04 am
    For some reason rendering a simple color grade, just one node, basic color correction, takes forever to render. It starts and stays at 1fps. I’ve checked my activity monitor and Resolve only uses 33% of my CPU, System: 5%, User: 5% Idle: 89% Everything else is closed down. I can’t figure this out. Below is my system. Any Ideas?
    Model Name: iMac
    Model Identifier: iMac14,2
    Processor Name: Intel Core i5
    Processor Speed: 3.4 GHz
    Number of Processors: 1
    Total Number of Cores: 4
    L2 Cache (per Core): 256 KB
    L3 Cache: 6 MB
    Memory: 16 GB
    Chipset Model: NVIDIA GeForce GTX 780M
    Type: GPU
    Bus: PCIe
    PCIe Lane Width: x16
    VRAM (Total): 4096 MB
    Vendor: NVIDIA (0x10de)
    Device ID: 0x119e
    Revision ID: 0x00a2
    ROM Revision: 3755
    Jordan Mena replied 12 years, 5 months ago 2 Members · 4 Replies
  • Jordan Mena
    April 30, 2014 at 4:57 am
    There is a setting in the deliver page that will allow you to change your render speed from maximum to 1 frame. You probably changed it to one frame and didn’t notice.
    Jordan Mena | Editor | Colorist | Producer
    Los Angeles, CA
    jordanmena.com
  • Charles Ford
    April 30, 2014 at 5:11 pm
    Thanks Jordan! That’s what happened. I’m new to Resolve and I guess I’m learning from my mistakes. I appreciate your help.
  • Charles Ford
    April 30, 2014 at 6:41 pm
    I have another question Jordan. When I export FCPXML to Resolve, any grouped set of clips above the primary story line in FCPX imports to Resolve as a “secondary storyline” in the form of a single clip, with any transitions created in FCPX imbedded in the clip. The individual clips in the group can not be color corrected individually. Is there a setting I have wrong in FCPX for exporting the XML or do I need to ungroup the secondary storyline clips before export to Resolve and add the transitions to the clips after they come back to FCPX from Resolve?
  • Jordan Mena
    May 1, 2014 at 3:30 am
    As a rule I always prep my sequence from any NLE before I go to color. Removing all unwanted clips, group clips or compound clips.
    Los Angeles, CA
    jordanmena.com
